| Applicable models : TS-2000 K/E/E2, TS-B2000 K/E/E2, TS-2000X K/E |
(Not applicable to the Japanese models TS-2000S/SX/TS-2000V/VX)
[Revision 15] |
Checksum
EFBA
The
latest
firmware.
Applied
from
S/No.B59xxxxx
approx. |
User
firmware
update
software
TS-2000
Ver.1.12
(28/July/2015
released) |
Revised the following symptom.
When using a single lever paddle, the internal electronic keyer occasionally generates extra dots or dashes. |
[Revision
14] |
Checksum
2BF7
Applied
from
S/No.B3Cxxxxx
approx. |
User
firmware
update
software
TS-2000
Ver.1.11
(15/November/2013
released) |
When DSP filter settings are changed using the ARCP-2000 software, RX audio might be distorted until the RX frequency or mode is changed.
[Revision 13] |
| Checksum =
5355 : The latest firmware. |
| Serial numbers: From S/NO.208xxxxx
through S/NO.B26xxxxx approx. |
User firmware update software :
TS-2000 Ver.1.10 (14/September/2012 released) |
Updated the
following item. |
When changing the
memory frequency temporary, auto zero-beat
(CW tune) function might not wok correctly. |
| [Revision 12] |
Checksum = 8BC9 : The latest firmware.
Applied from S/No.B13xxxxx approx. |
TS-2000 Ver.1.09 (30/June/2011 released) |
1. |
Updated the
following item.
Enabled the backup
of Auto Mode frequency points when Partial
Reset is executed as well as Memory channel
data or Menu settings. |
2. |
Revised the
following symptom.
When a separate RX
ANT is connected, TX output power may be fed
back to the RX ANT connector and might
affect internal circuits.
(The firmware Ver.1.09 deactivates (opens)
RX ANT relay every time the radio transmits.) |
| [Revision 11] |
Checksum = 8119 : The latest firmware.
Applied from S/No.003xxxxx approx. |
| User firmware update software : TS-2000
Ver.1.08 (18/July/2008 released) |
Updated the following
item.
Applied electrical compatibility with new component devices
as well as discontinued component devices used in the
1200MHz unit (UT-20).
(There is no functional change) |
Revision 10] |
Checksum = 89F6 : The latest firmware.
Applied from S/No.001xxxxx approx. |
Ver.1.07 (10/June/2008 released) |
item.
as well as discontinued component devices.
(There is no functional cahange) |
[Revision 9] |
Checksum = AF27 : The latest firmware. Applied from S/No.903xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.06 (6/September/2007 released) |
| | Updated following items:
| 1. | For ARISS split frequency operation, enabled direct frequency input (by means of PC commands) during TX in normal operation mode as well as SATL mode. | | 2. | Automatic Repeater Offset setting information is read when [A/B] key or [+]/[-] (Band select) key is pressed. |
| ![]() | | | | Revised following symptom:
| 1. | VS-3 (Optional Voice Synthesizer Unit) generates unnecessary announcement when Auto Mode is turned on. | | 2. | Reverse function may not work correct when [A/B] key is pressed. |
| [Revision 8] |
Checksum = 1D3F (1d3F) Applied from S/No.804xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.05(11/December/2006 released) |
| | Revised following symptom: Frequency step may change when a Quick Memory is registered after turned the main encoder knob to the anticlockwise direction. |
| [Revision 7] |
Checksum = BDEF (bdEF) Applied from S/No.612xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.04(28/January/2005 released) |
| | Updated following features:
| 1. | 7MHz band TX range is expanded to "7000kHz-7200kHz" for the TS-2000 E/E2, TS-B2000 E/E2, and TS-2000X E (European models). | | 2. | FM sub-audible tone functions (TONE/CTCSS/DCS) can be enabled in Satellite mode. |
| ![]() | | | | [Notes] *Although the sub-audible tone functions On/Off status is stored in each Satellite memory channel, the tone frequency/code cannot be stored due to the limited memory capacity.The tone frequency/code configuration from the normal VFO (VFO-A or VFO-B) is used instead.(The different tone frequency/code configuration can be stored in the HF, 50 MHz, 144 MHz, 430 MHz and 1.2 GHz band VFOs separately) | ![]() | | | | *Encoding and decoding is performed according to the data from the uplink frequency. *The tone frequency/code search function cannot be operated in Satellite mode. |
| [Revision 6] |
Checksum = 4611 Applied from S/No.506xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.03(1/August/2003 released) |
| | Revised following symptoms:| 1. | The APO (Auto Power OFF) timer is not reset by pressing PTT. | | 2. | After pressing the microphone's up/down switch, up/down operation on the ARCP-2000 may not work correctly. |
| [Revision 5] |
Checksum = BB7D (bb7d) Applied from S/No.405xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.02(12/September/2002 released) |
| | Revised following symptom: The S-meter flickers in FM mode when the LO/WIDTH knob or the HI/SHIFT knob is turned. |
| [Revision 4] |
Checksum = 8BD6 (8bd6) Applied from S/No.309xxxxx approx. |
| | Revised following symptoms:| 1. | In satellite mode, the frequency step information may not be displayed correctly. | | 2. | In satellite mode, QUICK MEMORY READ seldom displays vacant memory channels. |
| [Revision 3] |
Checksum = F095 (f095) Applied from S/No.301xxxxx approx. |
| User firmware update software : TS-2000 Ver.1.00(29/June/2001 released) |
| | Revised following symptoms:| 1. | If the PTT function is set to the sub band while writing to the main band memory, mode information may not be recorded correctly. | | 2. | If the SATL key is pressed to engage satellite mode while repeater operation is still in progress, the transceiver may not function properly. |
| [Revision 2] |
Checksum = 6D7A (6d7A) Applied from S/No.212xxxxx approx. |
| | Revised following symptom: When performing satellite operations, direct frequency input (by means of PC commands issued via the COM port) is not possible during an uplink. |
| [Revision 1] |
Checksum = A89D (A89d) Applied from S/No.209xxxxx approx. |
| | Revised following symptom: "A.NOTCH" and "B.C." icons remain on display when changed to CW/FSK mode. |
| [Revision 0] |
Checksum = 0DC6 (0dC6) : Original firmware. Applied from S/No.208xxxxx.(From the first production) |
Ниже прилагаю ссылку на подлинник статьи: |
| http://www.kenwood.com/i/products/info/amateur/ts2000_history_e.html |
| Редакция
от 23.11.2012
73! Wasil, UU2JJ |
