| Adjustment Menu TS-2000 Design by R7KK ex UU2JJ | CALL | N7BUI | UU2JJ | UU2JJ | UU1DX | ZS6BFD | RA9FTM | RA3ADR | ||
| Model | TS-2000 | TS-2000X | TS-2000 | TS-2000 | TS-2000E | TS-2000X | TS-2000X | |||
| Serial | № ??? | № 21000056 | № 70300105 | № 41200158 | № 60100041 | № 60100009 | № 30600050 | |||
| No. | A d j u s t m e n t i t e m | Frequency | Mode | D e f a u l t V a l u e | ||||||
| 00 | ALC reference voltage 14.1M | 14.1MHz | USB | 129 | 133 | 130 | 132 | 130 | 130 | 127 |
| 01 | 146M BPF center voltage (Main) 146MHz | 145.99MHz | USB | 160 | 160 | 160 | 160 | 160 | 160 | 160 |
| 02 | Variable capacitor voltage 142M | 142.00MHz | USB | 132 | 133 | 134 | 135 | 131 | 135 | 134 |
| 03 | Variable capacitor voltage 144M | 144.00MHz | USB | 143 | 146 | 146 | 148 | 141 | 146 | 149 |
| 04 | Variable capacitor voltage 148M | 148.10MHz | USB | 176 | 172 | 175 | 173 | 171 | 175 | 174 |
| 05 | Variable capacitor voltage 152M | 151.90MHz | USB | 255 | 252 | 255 | 217 | 226 | 246 | 211 |
| 06 | 435M BPF center voltage (Main) 440MHz | 440.00MHz | USB | 145 | 145 | 145 | 145 | 145 | 145 | 145 |
| 07 | Variable capacitor voltage 450M | 449.80MHz | USB | 171 | 173 | 167 | 177 | 168 | 173 | 173 |
| 08 | Variable capacitor voltage 430M | 430.00MHz | USB | 099 | 107 | 098 | 109 | 108 | 101 | 100 |
| 09 | Variable capacitor voltage 420M | 420.00MHz | USB | 038 | 062 | 043 | 051 | 063 | 051 | 050 |
| 10 | 146M BPF center voltage (Sub) 146MHz | 146.00MHz | FM | 090 | 090 | 090 | 090 | 090 | 090 | 090 |
| 11 | Variable capacitor voltage 118M | 118.00MHz | FM | 005 | 004 | 004 | 003 | 004 | 006 | 003 |
| 12 | Variable capacitor voltage 132M | 132.00MHz | FM | 043 | 044 | 045 | 041 | 044 | 042 | 043 |
| 13 | Variable capacitor voltage 160M | 160.00MHz | FM | 146 | 154 | 147 | 157 | 147 | 155 | 152 |
| 14 | Variable capacitor voltage 174M | 173.90MHz | FM | 253 | 254 | 253 | 255 | 255 | 255 | 255 |
| 15 | 440M BPF center voltage (TX) 435MHz | 435.10MHz | USB | 131 | 131 | 131 | 131 | 131 | 131 | 131 |
| 16 | Variable capacitor voltage 420M | 420.10MHz | USB | 037 | 028 | 051 | 034 | 031 | 046 | 012 |
| 17 | Variable capacitor voltage 440M | 439.99MHz | USB | 154 | 156 | 155 | 159 | 157 | 159 | 164 |
| 18 | Variable capacitor voltage 450M | 449.90MHz | USB | 246 | 228 | 255 | 249 | 206 | 254 | 208 |
| 19 | Variable capacitor voltage (HF TX) 14MHz | 14.10MHz | USB | 120 | 109 | 120 | 125 | 118 | 119 | 132 |
| 20 | 10.695M IF filter window 10.695MHz | 1.83MHz | USB | 90000150 | 90000260 | 90000240 | 90000190 | 90000140 | 90000150 | 90000280 |
| 21 | 455kHz IF filter window 455kHz | 1.83MHz | USB | 00000110 | 00000130 | 00000070 | 00000090 | 00000150 | 00000130 | 00000150 |
| 22 | SSB IF gain SSB start HF | 14.2MHz | USB | 0 | 0 | 0 | 0 | 0 | 0 | 019 |
| 23 | SSB S1 SSB S1 HF | 14.2MHz | USB | 48 | 60 | 58 | 58 | 65 | 68 | 59 |
| 24 | SSB S9 SSB S9 HF | 14.2MHz | USB | 249 | 235 | 253 | 219* | 262 | 262 | 241 |
| 25 | SSB S-full scale SSB S full HF | 14.2MHz | USB | 451 | 427 | 448 | 456 | 443 | 460 | 440 |
| 26 | FM S1 FM S1 HF | 29.2MHz | FM | 045 | 036 | 041 | 041 | 042 | 039 | 039 |
| 27 | FM S-full scale FM full HF | 29.2MHz | FM | 073 | 066 | 069 | 070 | 069 | 066 | 066 |
| 28 | SSB IF gain SSB start 50MHz | 50.2MHz | USB | 0 | 0 | 0 | 046* | 0 | 0 | 019 |
| 29 | SSB S1 SSB S1 50MHz | 50.2MHz | USB | 60 | 54 | 51 | 52 | 56 | 60 | 49 |
| 30 | SSB S9 SSB S9 50MHz | 50.2MHz | USB | 251 | 234 | 252 | 254 | 260 | 260 | 239 |
| 31 | SSB S-full scale SSB S full 50MHz | 50.2MHz | USB | 462 | 432 | 457 | 468 | 455 | 468 | 447 |
| 32 | FM S1 FM S1 50MHz | 50.2MHz | FM | 048 | 040 | 044 | 045 | 046 | 042 | 043 |
| 33 | FM S-full scale FM full 50MHz | 50.2MHz | FM | 076 | 071 | 073 | 075 | 073 | 069 | 070 |
| 34 | SSB IF gain SSB start 144MHz | 144.20MHz | USB | 0 | 0 | 0 | 037* | 0 | 0 | 019 |
| 35 | SSB S1 SSB S1 144MHz | 144.20MHz | USB | 72 | 56 | 57 | 60 | 61 | 64 | 63 |
| 36 | SSB S9 SSB S9 144MHz | 144.20MHz | USB | 235 | 223 | 239 | 236 | 241 | 245 | 225 |
| 37 | SSB S-full scale SSB S full 144MHz | 144.20MHz | USB | 408 | 396 | 409 | 409 | 406 | 418 | 400 |
| 38 | FM S1 FM S1 145.8MHz | 145.80MHz | FM | 046 | 042 | 042 | 039 | 043 | 041 | 040 |
| 39 | FM full scale FM full 145.8MHz | 145.80MHz | FM | 075 | 074 | 070 | 068 | 070 | 068 | 067 |
| 40 | FM S1 (SUB) FM S1 145.8MHz | 145.80MHz | FM | 055 | 055 | 056 | 051 | 057 | 052 | 051 |
| 41 | FM full scale (SUB) FM full 145.8MHz | 145.80MHz | FM | 083 | 083 | 084 | 080 | 085 | 081 | 079 |
| 42 | AM S1 AM S1 120.2MHz | 120.20MHz | AM | 050 | 053 | 053 | 052 | 041 | 048 | 052 |
| 43 | AM S-full scale AM full 120.2MHz | 120.20MHz | AM | 064 | 067 | 067 | 067 | 062 | 064 | 067 |
| 44 | SSB IF gain SSB start 438.2MHz | 438.20MHz | USB | 0 | 0 | 0 | 022* | 0 | 0 | 019 |
| 45 | SSB S1 SSB S1 438.2MHz | 438.20MHz | USB | 67 | 59 | 56 | 52 | 55 | 61 | 60 |
| 46 | SSB S9 SSB S9 438.2MHz | 438.20MHz | USB | 234 | 224 | 239 | 235 | 240 | 245 | 224 |
| 47 | SSB S-full scale SSB S full 438.2MHz | 438.20MHz | USB | 407 | 399 | 411 | 410 | 406 | 419 | 401 |
| 48 | FM S1 FM S1 438.2MHz | 438.20MHz | FM | 050 | 051 | 047 | 046 | 038 | 047 | 047 |
| 49 | FM S-full scale FM full 438.2MHz | 438.20MHz | FM | 078 | 082 | 076 | 076 | 065 | 074 | 074 |
| 50 | FM S1 (SUB) FM S1 438.2MHz | 438.20MHz | FM | 052 | 055 | 054 | 053 | 050 | 052 | 052 |
| 51 | FM S-full scale (SUB) FM full 438.2MHz | 438.20MHz | FM | 081 | 083 | 083 | 081 | 079 | 080 | 080 |
| 52 | SSB IF gain SSB start 1270.2MHz | 1270.20MHz | USB | 0 | 0 | 0 | 0 | 0 | 0 | 019 |
| 53 | SSB S1 SSB S1 1270.2MHz | 1270.20MHz | USB | 65535 | 140 | 65535 | 65535 | 65535 | 61 | 60 |
| 54 | SSB S9 SSB S9 1270.2MHz | 1270.20MHz | USB | 65535 | 258 | 65535 | 65535 | 65535 | 251 | 234 |
| 55 | SSB S-full scale SSB S full 1270.2MHz | 1270.20MHz | USB | 65535 | 422 | 65535 | 65535 | 65535 | 419 | 407 |
| 56 | FM S1 FM S1 1270.2MHz | 1270.20MHz | FM | 255 | 053 | 255 | 255 | 255 | 047 | 048 |
| 57 | FM S-full scale FM full 1270.2MHz | 1270.20MHz | FM | 255 | 083 | 255 | 255 | 255 | 075 | 075 |
| 58 | ALT voltage Center 1270.2MHz | 1270.20MHz | FM | 000 | 079 | 000 | 000 | 000 | 040 | 060 |
| 59 | ALT voltage Center 145.8MHz | 145.80MHz | FM | 000 | 000 | 000 | 000 | 000 | 000 | 000 |
| 60 | SQ threshold voltage FM 50.2MHz | 50.2MHz | FM | 079 | 081 | 070 | 076 | 074 | 075 | 080 |
| 61 | SQ threshold voltage (144M) FM | 145.80MHz | FM | 083 | 083 | 077 | 080 | 079 | 077 | 081 |
| 62 | SQ tight voltage (144M) FM | 145.80MHz | FM | 019 | 021 | 022 | 032 | 027 | 027 | 030 |
| 63 | SQ threshold voltage (144M) FM | 145.80MHz | FM | 071 | 071 | 073 | 073 | 067 | 073 | 071 |
| 64 | SQ tight voltage (144M) FM | 145.80MHz | FM | 008 | 009 | 009 | 012 | 005 | 011 | 014 |
| 65 | SQ threshold voltage (430M) FM | 438.20MHz | FM | 080 | 077 | 081 | 078 | 078 | 078 | 076 |
| 66 | SQ threshold voltage (430M) FM | 438.20MHz | FM | 083 | 083 | 076 | 078 | 080 | 076 | 082 |
| 67 | SQ threshold voltage (1200M) FM | 1270.20MHz | FM | 255 | 082 | 255 | 255 | 255 | 075 | 079 |
| 68 | Power (POC)/Power meter 100W/20W HF | 14.1MHz | USB | 162 | 165 | 168 | 181 | 190 | 167 | 157 |
| 69 | Power (POC)/Power meter 50W/10W HF | 14.1MHz | USB | 114 | 117 | 117 | 119 | 134 | 119 | 111 |
| 70 | Power (POC)/Power meter 25W/5W HF | 14.1MHz | USB | 079 | 084 | 083 | 086 | 076 | 084 | 076 |
| 71 | Power (POC)/Power meter 10W/2W HF | 14.1MHz | USB | 052 | 057 | 055 | 060 | 063 | 057 | 050 |
| 72 | Power (POC)/Power meter 5W/1W HF | 14.1MHz | USB | 039 | 043 | 042 | 042 | 042 | 043 | 037 |
| 73 | TX gain for band 1.8MHz | 1.83MHz | USB | 132 | 128 | 117 | 132 | 088 | 117 | 098 |
| 74 | TX gain for band 3.5MHz | 3.51MHz | USB | 198 | 195 | 193 | 193 | 169 | 195 | 175 |
| 75 | TX gain for band 7MHz | 7.01MHz | USB | 203 | 193 | 194 | 191 | 169 | 195 | 175 |
| 76 | TX gain for band 10MHz | 10.1MHz | USB | 224 | 201 | 220 | 204 | 189 | 211 | 209 |
| 77 | TX gain for band 14MHz | 14.1MHz | USB | 217 | 195 | 215 | 199 | 187 | 203 | 202 |
| 78 | TX gain for band 18MHz | 18.1MHz | USB | 203 | 195 | 200 | 195 | 163 | 197 | 190 |
| 79 | TX gain for band 21MHz | 21.1MHz | USB | 185 | 158 | 180 | 170 | 170 | 167 | 147 |
| 80 | TX gain for band 24MHz | 24.9MHz | USB | 207 | 178 | 204 | 186 | 166 | 195 | 195 |
| 81 | TX gain for band 28MHz | 28.1MHz | USB | 188 | 168 | 185 | 172 | 143 | 178 | 156 |
| 82 | TX gain for band 50MHz | 50.1MHz | USB | 145 | 109 | 145 | 145 | 119 | 155 | 145 |
| 83 | HF TX gain for power 50W/10W | 14.1MHz | USB | 052 | 051 | 052 | 051 | 057 | 052 | 051 |
| 84 | HF TX gain for power 25W/5W | 14.1MHz | USB | 071 | 068 | 071 | 068 | 077 | 070 | 70 |
| 85 | HF TX gain for power 10W/2W | 14.1MHz | USB | 110 | 098 | 107 | 101 | 123 | 102 | 107 |
| 86 | HF TX gain for power 5W/1W | 14.1MHz | USB | 145 | 130 | 140 | 136 | 179 | 135 | 139 |
| 87 | ALC meter start HF | 14.1MHz | USB | 073 | 078 | 077 | 072 | 056 | 083 | 081 |
| 88 | ALC meter Zone max HF | 14.1MHz | USB | 099 | 102 | 102 | 090 | 088 | 106 | 104 |
| 89 | FM modulation deviation Wide dev 29MHz | 29.1MHz | FM | 045 | 042 | 048 | 050 | 055 | 047 | 046 |
| 90 | FM modulation deviation Narrow dev 29MHz | 29.1MHz | FM | 048 | 050 | 052 | 050 | 060 | 050 | 052 |
| 91 | Power (POC) / Power meter 100W/20W VHF | 145.90MHz | USB | 160 | 150 | 151 | 160 | 179 | 147 | 157 |
| 92 | Power (POC) / Power meter 50W/10W VHF | 145.90MHz | USB | 105 | 101 | 100 | 100 | 100 | 99 | 100 |
| 93 | Power (POC) / Power meter 25W/5W VHF | 145.90MHz | USB | 068 | 068 | 068 | 067 | 068 | 067 | 065 |
| 94 | Power (POC) / Power meter 10W/2W VHF | 145.90MHz | USB | 041 | 043 | 041 | 038 | 042 | 038 | 040 |
| 95 | Power (POC) / Power meter 5W/1W VHF | 145.90MHz | USB | 028 | 032 | 029 | 025 | 030 | 028 | 026 |
| 96 | TX gain for band 146MHz | 145.90MHz | USB | 183 | 166 | 171 | 152 | 150 | 170 | 166 |
| 97 | 144M TX gain for power 50W/10W VHF | 145.90MHz | USB | 061 | 060 | 059 | 063 | 058 | 059 | 063 |
| 98 | 144M TX gain for power 25W/5W VHF | 145.90MHz | USB | 091 | 084 | 086 | 088 | 083 | 081 | 092 |
| 99 | 144M TX gain for power 10W/2W VHF | 145.90MHz | USB | 140 | 127 | 130 | 138 | 127 | 137 | 137 |
| 100 | 144M TX gain for power 5W/1W VHF | 145.90MHz | USB | 186 | 169 | 172 | 181 | 170 | 170 | 183 |
| 101 | Power (POC) / Power meter 50W/20W UHF | 438.10MHz | USB | 159 | 154 | 159 | 156 | 157 | 161 | 160 |
| 102 | Power (POC) / Power meter 25W/10W UHF | 438.10MHz | USB | 113 | 115 | 113 | 107 | 115 | 115 | 112 |
| 103 | Power (POC) / Power meter 12.5W/5W UHF | 438.10MHz | USB | 080 | 081 | 080 | 077 | 081 | 083 | 080 |
| 104 | Power (POC) / Power meter 5W/1W UHF | 438.10MHz | USB | 052 | 053 | 053 | 048 | 055 | 055 | 052 |
| 105 | TX gain for band 440MHz | 438.10MHz | USB | 065 | 082 | 065 | 065 | 068 | 114 | 075 |
| 106 | 440M TX gain for power 25W/10W | 438.10MHz | USB | 059 | 058 | 060 | 054 | 070 | 060 | 064 |
| 107 | 440M TX gain for power 12.5W/5W | 438.10MHz | USB | 079 | 079 | 079 | 072 | 099 | 080 | 088 |
| 108 | 440M TX gain for power 5W/1W | 438.10MHz | USB | 121 | 119 | 115 | 109 | 149 | 119 | 136 |
| 109 | Power (POC) / Power meter 10W SHF | 1270.10MHz | USB | 127 | 185 | 127 | 127 | 127 | 144 | 129 |
| 110 | Power (POC) / Power meter 5W SHF | 1270.10MHz | USB | 095 | 131 | 095 | 095 | 095 | 103 | 092 |
| 111 | Power (POC) / Power meter 2.5W SHF | 1270.10MHz | USB | 063 | 097 | 063 | 063 | 063 | 072 | 061 |
| 112 | Power (POC) / Power meter 1W SHF | 1270.10MHz | USB | 047 | 063 | 047 | 047 | 047 | 046 | 040 |
| 113 | TX gain for 1.2GHz band | 1240.10MHz | USB | 063 | 188 | 063 | 063 | 063 | 223 | 185 |
| 114 | TX gain for 1.2GHz band | 1270.10MHz | USB | 063 | 190 | 063 | 063 | 063 | 214 | 185 |
| 115 | TX gain for 1.2GHz band | 1299.90MHz | USB | 063 | 218 | 063 | 063 | 063 | 230 | 213 |
| 116 | 1.2G TX gain for power 2.5W | 1270.10MHz | USB | 047 | 054 | 047 | 047 | 047 | 051 | 056 |
| 117 | 1.2G TX gain for power 1W | 1270.10MHz | USB | 063 | 068 | 063 | 063 | 063 | 062 | 070 |
| 118 | SWR protection HF | 14.1MHz | CW | 056 | 054 | 056 | 054 | 057 | 059 | 054 |
| 119 | SWR meter (VSWR : 3.0) 14MHz | 14.1MHz | FM | 164 | 182 | 175 | 204 | 179 | 185 | 206 |
| 120 | SWR meter (VSWR : 3.0) 50MHz | 50.1MHz | CW | 161 | 156 | 163 | 207 | 167 | 158 | 163 |
| 121 | SWR protection 146MHz | 145.90MHz | CW | 167 | 175 | 186 | 219 | 194 | 212 | 150 |
| 122 | SWR protection 438MHz | 438.10MHz | CW | 107 | 107 | 108 | 117 | 111 | 087 | 078 |
| 123 | SWR protection 1296MHz | 1270.10MHz | CW | 020 | 173 | 020 | 020 | 020 | 108 | 105 |
| 124 | EEPROM write "ready" "ready" | - | - | "ready" | "ready" | "ready" | "ready" | "ready" | "ready" | "ready" |
| 125 | Checksum | - | - | 6596 9492E8A9 | 6596 2511E8A9 | 6596 9492E8A9 | 6596 7E83E8A9 | 6596 9492E8A9 | 6596 9492E8A9 | 6596 2511E8A9 |
| 126 | D i s p l a y c h e c k / A c t i v a t e a l l t h e A T r e l a y c o n t a c t s | |||||||||
Remark : * - change UU1DX
/ Вернуться на главную / Вернуться в тему /
